Начать новую тему Ответить на тему  [ Сообщений: 57 ]  На страницу Пред.  1, 2, 3, 4, 5, 6  След.
 Заголовок сообщения: Re: Linear Conchord. Английский звук - лучший звук !
СообщениеДобавлено: 22 янв 2012, 12:03
Поступил в реставрацию моноблок Linear, в котором уже в Англии удалены внутренние платы и элементы регулировки тембров.
Прошу смотреть и сравнивать с заводским решением:
СообщениеДобавлено: 04 фев 2012, 18:39
Послушали моноблоки Linear Conchord с акустикой Lowther.
http://www.lowtherloudspeakers.com/fid-acad.html
Хорошо играют, но шум первой лампы EF86 немного мешает.
Поэтому надо ее тщательно выбирать.
Выбор велик!!!
https://www.tubeworld.com/6267.htm
Например, эти
EF806S Telefunken West Germany
Low Noise
(reference quality EF86 for the most demanding low-noise applications)
Обсуждение проблемы шипения EF86 на зарубежных форумах:
Richard said:
August 17th, 2009 on 15:59
Oh don’t reverse engineer the amp!! I thought it might have been the ac30 you were modelling the changes after Im tempted to change valves around a bit to try and find the one which hisses the least. Ive heard the ef806s are good (just a shame i cant afford the telefunken ones at 240 odd pounds for two!!) but ive seen the jj and svetlana winged c ones about for 30 pounds for two and I’d be tempted to try them first but if not sadly the efs may become eccs. Before then though, after I posted the first message, I found that I can turn down the gain stage to see if any hiss goes (also no matter what the level is, whether it be 0 or 10 the hiss is at the same constant level so its definately the ef86s). Im very happy theres next to no hum though Ill have to have a good play first with that but its nice to know there was once someone in the same position as me heheheh. Also I think I’m going to move round the start of the heater wiring to the closest place to the transformer ie the el34s instead of the light where it is currently set up as a ring main and that should completely destroy any hum.
Ill have to send some photos of the finished piece once ive tinkered a bit more
Thank you very much for your help Ben
bounav said:
August 19th, 2009 on 10:41
Hi Richard,
I tried swapping the Mullard EF86s with a new pair EF86 (can’t remember the make) and it was just a noisy. Decreasing the gain should reduce the noise in theory. I’m curious to hear if it works for you.
I remeber having a chat about EF86 noise with John Chambers and he told be that EF86 valves built with a mesh (as opposed to plate) sheild tend to be noisier…
Please let us know if moving the heater wires closer to the EL34 reduces hum.
I’d love to see pictures of your amp, don’t hesitate sending some and I’ll put them here.
Cheers!
bounav said:
October 19th, 2009 on 14:07
Replacing all electrolytic capacitors is a good idea indeed and will help reducing the hum and general performance of the amp. You could also replace all the other capacitors (especially the greasy aluminium foil ones). Replacing the resistor with metal film one should also help reducing noise and clarity a bit.
As far as I recall the original design sets the EF86s in very high gain pentode mode, which has the drawback of generating a lot of white noise and making the EF86s very prone to produce microphonics.
СообщениеДобавлено: 21 фев 2012, 22:18
Тем, кто ищет лучшие EF86, может помочь эта ссылка
http://www.jogis-roehrenbude.de/Roehren ... 6/Ef86.htm
добавьте к списку Telefunken EF804
СообщениеДобавлено: 23 фев 2012, 13:42
Схема очередного Linear Conchord была упрощена максимально. Остались лишь три лампы.
Предлагаю послушать его с динамиком Feho
Sarah Vaughan AML+
http://www.youtube.com/watch?v=KUgI3uwA ... e=youtu.be
и Sarah Vaughan фабричного производства.
http://www.youtube.com/watch?v=g85S-4uI ... e=youtu.be
sara.jpg [ 8.83 КБ | Просмотров: 16063 ]
СообщениеДобавлено: 23 фев 2012, 16:37
Alfred Schnittke
http://www.youtube.com/watch?v=XnbubQKcDns
schnitke.jpg [ 4.4 КБ | Просмотров: 16053 ]
СообщениеДобавлено: 10 мар 2012, 10:24
Рекомендую !
http://www.ebay.co.uk/itm/LINEAR-50-ORI ... 218wt_1185
С восстановлением помогу!
СообщениеДобавлено: 16 июн 2012, 00:33
Может, для коллекции?...
Very Rare Vintage 1950`s RSC A10 Valve amplifier made in Leeds in the UK approx 1956 it`s the predecessor to the Linear Conchord.Fantastic condition for it`s age and in excellent working order.Except for a Brand New JJ GZ34 rectifier and 6SN7GT eq phase splitter valve several NOS mustard capacitors and a new mains lead it is completely original and in excellent working order.Comes with it`s metal base plate and louvred cover.The last picture is of an original advert in the Wireless World February 1960 (slightly later version) when it cost 11 gns - £11 and 11/- shillings.This is only for the UK as postage will be expensive due to it`s weight.
СообщениеДобавлено: 10 фев 2013, 23:08
И все же, что лучше для записи
айфон 2012 года или мыльница Canon 2005 года ?
http://youtu.be/xZqpMWUmz64
СообщениеДобавлено: 16 мар 2016, 19:50
И снова играют английские моноблоки
Linear Conchord на EL34 от Mullard
http://youtu.be/9fLKfexv5bk
СообщениеДобавлено: 21 мар 2016, 14:14
Борис Кинер и Михаил Цитриняк начали петь дуэтом 40 лет назад, еще в 1976-м году
http://www.mastergrisha.ru/biograf.php
http://youtu.be/QwZEyzRKQxw
