Начать новую тему Ответить на тему  [ Сообщений: 186 ]  На страницу 1, 2, 3, 4, 5 ... 19  След.
 Заголовок сообщения: Япония о которой мы не знали
СообщениеДобавлено: 25 авг 2010, 12:47
Speaker for the field type
Cone speaker unit has been manufactured in our field type ( type excitation ) is the type of magnetic circuit with an electromagnet called . Already a professional brand for the 1940 full range driver . "LIST" As a unit D-1, D-2Manufacturing has been proven , is that many fans still support it , then the product material at the time , we re- started production of manufactured goods from production to reproduction in .
The golden era of so-called electromagnetic field type of magnet in difficult times to obtain high-quality (type excitation ), the unit has adopted the speaker 's magnetic circuit was a top priority of mass production by using modern high-tech materials without human Appeal to the sense of "something" is certainly existed . Pure sound produced by the magnetic circuit of permanent magnet type of excitation is also confirmed to be able not reach really high levels .
Production unit which had been abandoned more and more important element to determine cut the sound of a speaker assumes the mass production of these facts will provide the user with limited original handmade speaker not an ideal Our views .
Development of a large speaker unit will begin the design time and cost of each component is essential that experience and passion more than anything else . Therefore this product has been expressed our Kodawari .
Продукция 1940 года!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
http://www5b.biglobe.ne.jp/~chosho/PDF/LIST.pdf
От себя хочу добавить,сравнивал звучание LIST 12" с Тел.12 оба филд коил.....первое впечатление ....тел. даёт красивее звук ......при прослушивании Лист ,сначала ничего.....потом "догоняет " и совсем сьезжает крыша..... :shock: Магнитная система у япошек тяжелее в 4 раза !!!!...магнитопровод сделан из особочистого многослойного отожженого железа ....какой нах тел....
СообщениеДобавлено: 25 авг 2010, 15:04
Братья по разуму
СообщениеДобавлено: 26 авг 2010, 17:08
Неплохие басовички
СообщениеДобавлено: 26 авг 2010, 17:10
Ух, красавцы!..
СообщениеДобавлено: 27 авг 2010, 12:20
Купил одного такого красавца....
СообщениеДобавлено: 29 авг 2010, 15:01
Комментарии.....
СообщениеДобавлено: 29 авг 2010, 16:09
Так и где же они - комментарии?
СообщениеДобавлено: 29 авг 2010, 18:00
Квартира спикер ? Слушай ! !
?Кон старого принципа (конус) от говорящего, оратор может подумать, что самолет не был известен, но оратор не было видение длинных продуктов, которые сложно и дорого производства? 1Мы разработали плоскости диафрагмы весит 0,8 грамма и яркого света , в мире быстрый рост достигнут. До музыки и четкость звучания локализации, стартовый номер , и даже подавить конуса , на котором исходный код программы .
Какие выстроились вдоль конуса с плоской частью 1 ? производителей продуктов присутствовали.
Система (фото справа , дом 04 торрент Окамото (специальный) , корпус выполнен из Rafutokurafuto )
---Окамото дом 04 торрентДобавить фотографии ---
Обычные динамики к рупор ? !
Обычные конусе динамика ( конус), но с использованием диафрагмы , это не главная причина это звучит лучше. При преобразовании электрического сигнала в звук, и ошибка актуальных воздуха на склонах. Пресс бежать на воздух боковых склонах(?1)не будут эффективными, и играть на бас , по сравнению с 3 -квартирный области потребуется шесть раз попытается получить значительно тяжелее , что область будет расти на плохой звук плохой торможения. И воздух бежать , когда сбоку странный артефакт фазовых искажений. Это накопившегося звук становится мутной, звук не живой звук и тактильные далеко. ( Нет основания для звука ?)
СообщениеДобавлено: 29 авг 2010, 18:16
Миша, а мой центростремительный подвес (ты ему, кстати, название не придумал?), кажется, оченьно сюда подойдет, а?..
СообщениеДобавлено: 29 авг 2010, 18:22
Придумал......ПУШПУЛЬНЫЙ ПОДВЕС! :shock:
