Начать новую тему Ответить на тему  [ Сообщений: 9 ]
 Заголовок сообщения: Резонанс динамика и граничная частота
СообщениеДобавлено: 07 май 2011, 15:07
Kl406 один из шедевров в мире для щитов работает по паспорту от 50герц ,а какая у него самого резонансная?
Есть мнение ,что ниже резонансной ни в каком оформлении нельзя получить бас.
Опровергли это мнение инженеры Клангфильм и господин КОНДО резонансная его динамика 65 герц! А акустика работает с......40гц
Читая эти комментарии сразу понимаю ,что человек владеет не только Клангами ,но и восприятием музыки.
Anjello
These drivers (Philips 5502/5500)were made in Breda in the Netherlands by the Philips Ela division. All this ela stuff of Philips is absolutely wonderful. So nicely build, and good sounding. Just a little under appreciated, not the drivers and speakers but the amps. The compression driver of Philips are much better than the ones from klangfilm, only the low units of klangfilm are better than the ones from Philips. My favourite is the kl406, the best speaker I have ever heard in my life. Nothing comes close to it, this speaker is a little bas shy but what a details you’ll hear with this speaker. Details you never knew the were there in the low freq to mid freq. And this speaker can easily be used up to 5 kHz if its needed. I managed to get my hands on 4 of these speakers. Gone use 2 a channel for low and low mids with above it the vitavox (from 1.1 kHz to 11 kHz ) above that I’m gone use the jbl 2403 cat eye horn tweeter. I also have plans to use a vitavox s2 with a shorter horn but then from 7 kHz and not 11 kHz. The plans are there to take an other horn in production. To make a 3 way system with 2 vitavox drivers a channel. Because the upper mids of the vitavox are really nice. But also the jbl is nice ( 2403 ).
And yes till now my big favourite is the vitavox s2 with beside it the Philips el5502 and it sisters. Did you know that the Philips has a bras phase plug? That is nicer designed than the one of vitavox. Ill send you some pics of that. And I will also ad some pictures of the Philips with its paper diaphragm. I have a lot of pics of all the drivers I tested, even from there diaphragms. You can always ask for them if you need them for your site.
 Заголовок сообщения: Re: Резонанс динамика и граничная частота
СообщениеДобавлено: 07 май 2011, 16:48
Михаил-а что за дины Кланги 42006 ?
СообщениеДобавлено: 07 май 2011, 16:55
http://soundup.ru/index.php?option=com_ ... &Itemid=45
Леонид ,подозреваю ,что ты интересовался 44006 ZETTON ?
http://www.tubebbs.com/viewthread.php?a ... &tid=52634
СообщениеДобавлено: 07 май 2011, 17:31
Серьезный подход , спасибо Михаил за ссылку !
СообщениеДобавлено: 07 май 2011, 18:41
Михаил именно Клангфильм КЛ42006----
СообщениеДобавлено: 09 май 2011, 04:59
не плохо этот динамик отвалился!
За 3250$ :)
http://cgi.ebay.de/Klangfilm-Speaker-KL ... 43a6bf9cf0
СообщениеДобавлено: 09 май 2011, 14:56
.Вчера слушал камерный ансамбль в музее Голубкиной в Москве ,две скрипки ,альт ,виолончель,рояль и пела ещё оперная певица......пытался представить какой динамик может хоть чуть-чуть напомнить это звучание в нижнем регистре......кланги и только КЛАНГИ.... 405й и 406 звучат вместе .На голосе......не динамик вообще ...нет ещё такого динамика.... :(
Во время игры молодой скрипачки пытался на слух определить какого года инструмент......1850....1860.....нет 1870й! Европа..... нет не Италия ,там звучание более сладковатое что-ли..... Думаю интересно подойду спрошу после концерта.Позабыл ...стали разговаривать в кругу о скульпторе Голубкиной о её подруге оказавшейся женой Кусевицкого...Да Да!... того Кусевицкого!!! В конце вспомнил про скрипку и рассказал о своих впечатлениях .....Андрей Чистяков учавствовавший в концерте говорит ..."Так давай спросим!"......подошли ..спросили ,думаю сейчас облажаюсь...скажут советская....1970й итд..
....вот говорю.....1870й.... :? .показалось..... "ДА ЭТО 1872 год Австро-Венгрия!"
С приподнятым настроением пошли по садовому.С праздником Всех! :)
СообщениеДобавлено: 09 май 2011, 17:23
В деле построения головок для громкоговорителей приходится любому проектанту ( автору) учитывать два аспекта - физический и мистический. Резонанс и граничная частота как хошь,но упираются в физику подвеса ,веса диффузора и прочее. Но состав материала диффузора или проще поставляя вопрос -существует ли мистика ( тайна) его состава ,технологии , которые и позволяют получать приемлемый( прогнозируемый) результат ,согласно уровня автора ? Думаю , что в массовом аспекте - способность диффузора ложиться ( через музыку ес.) на наше восприятие ( часто подсознательное) - есть основа основ и остальное реально раскрывает эту основу . Прежде всего - это подвес , центрирущая шайба и магнитная система. Интуитивно ощущаю ,что особый магнетизм , баланс -в звучании Клангфильм завязан имеено на МС. Мощный ,высокоиндуктивный мотор обеспечивает реально выведение "спутника" Клангфильм на геостационарную орбиту высшего качества. Особенно удивило : фирма Фокал применила в акустике "УТОПИЯ" динамики НЧ на подмагничивании . Похоже это уже не смешно.
СообщениеДобавлено: 09 май 2011, 18:13
Михаил, еще провод звуковой катушки очень важен.Как и провод э/магнита
