| Япония о которой мы не знали http://forum.soundup.ru/viewtopic.php?f=3&t=377 |
Страница 1 из 19 |
| Автор: | urakoff [ 25 авг 2010, 12:47 ] | ||||
| Заголовок сообщения: | Япония о которой мы не знали | ||||
Speaker for the field type Cone speaker unit has been manufactured in our field type ( type excitation ) is the type of magnetic circuit with an electromagnet called . Already a professional brand for the 1940 full range driver . "LIST" As a unit D-1, D-2Manufacturing has been proven , is that many fans still support it , then the product material at the time , we re- started production of manufactured goods from production to reproduction in . The golden era of so-called electromagnetic field type of magnet in difficult times to obtain high-quality (type excitation ), the unit has adopted the speaker 's magnetic circuit was a top priority of mass production by using modern high-tech materials without human Appeal to the sense of "something" is certainly existed . Pure sound produced by the magnetic circuit of permanent magnet type of excitation is also confirmed to be able not reach really high levels . Production unit which had been abandoned more and more important element to determine cut the sound of a speaker assumes the mass production of these facts will provide the user with limited original handmade speaker not an ideal Our views . Development of a large speaker unit will begin the design time and cost of each component is essential that experience and passion more than anything else . Therefore this product has been expressed our Kodawari . Продукция 1940 года!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! http://www5b.biglobe.ne.jp/~chosho/PDF/LIST.pdf От себя хочу добавить,сравнивал звучание LIST 12" с Тел.12 оба филд коил.....первое впечатление ....тел. даёт красивее звук ......при прослушивании Лист ,сначала ничего.....потом "догоняет " и совсем сьезжает крыша.....
| Автор: | urakoff [ 25 авг 2010, 15:04 ] | |||||
| Заголовок сообщения: | Re: Япония о которой мы не знали | |||||
Братья по разуму
| Автор: | urakoff [ 26 авг 2010, 17:08 ] | ||
Неплохие басовички
| Автор: | Евгений [ 26 авг 2010, 17:10 ] | ||
Ух, красавцы!..
| Автор: | urakoff [ 27 авг 2010, 12:20 ] | ||||
Купил одного такого красавца....
| Автор: | urakoff [ 29 авг 2010, 15:01 ] | |||
Комментарии.....
| Автор: | Евгений [ 29 авг 2010, 16:09 ] | ||
Так и где же они - комментарии?
| Автор: | urakoff [ 29 авг 2010, 18:00 ] | ||||
Квартира спикер ? Слушай ! ! ?Кон старого принципа (конус) от говорящего, оратор может подумать, что самолет не был известен, но оратор не было видение длинных продуктов, которые сложно и дорого производства? 1Мы разработали плоскости диафрагмы весит 0,8 грамма и яркого света , в мире быстрый рост достигнут. До музыки и четкость звучания локализации, стартовый номер , и даже подавить конуса , на котором исходный код программы . Какие выстроились вдоль конуса с плоской частью 1 ? производителей продуктов присутствовали. Система (фото справа , дом 04 торрент Окамото (специальный) , корпус выполнен из Rafutokurafuto ) ???????? ---Окамото дом 04 торрентДобавить фотографии --- Обычные динамики к рупор ? ! Обычные конусе динамика ( конус), но с использованием диафрагмы , это не главная причина это звучит лучше. При преобразовании электрического сигнала в звук, и ошибка актуальных воздуха на склонах. Пресс бежать на воздух боковых склонах(?1)не будут эффективными, и играть на бас , по сравнению с 3 -квартирный области потребуется шесть раз попытается получить значительно тяжелее , что область будет расти на плохой звук плохой торможения. И воздух бежать , когда сбоку странный артефакт фазовых искажений. Это накопившегося звук становится мутной, звук не живой звук и тактильные далеко. ( Нет основания для звука ?)
| Автор: | Евгений [ 29 авг 2010, 18:16 ] |
Миша, а мой центростремительный подвес (ты ему, кстати, название не придумал?), кажется, оченьно сюда подойдет, а?.. |
| Автор: | urakoff [ 29 авг 2010, 18:22 ] |
Придумал......ПУШПУЛЬНЫЙ ПОДВЕС! |
| Страница 1 из 19 | Часовой пояс: UTC + 3 часа |
